newman_fulltime
Jun 02, 2015Explorer II
Dtank wrote:newman fulltimer wrote:
Put a electric valve on and make it easy on yourself
He has bad shoulders, etc.
Also - real PITA if the valve is hard to access.
So - most likely he will have to pay to have it done.
EASY -inexpensive- solution: just add a Valterra T-58 Twist-On Waste valve at the end of the drain.
About $20 from Amazon.
BTW - everyone should carry one for when your remotely operated cable or *ELECTRIC* valve fails (at the valve)...;)
Did you ever think he could have it installed?And they have a less failure rate than a lot of the manual ones.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
