TGPILOT's avatar
TGPILOT
WI-FI EXTENDER IN A FW
Okay guys, getting ready to head out in a few weeks to spend a few months back in ID and MT. Will also be in and around the Teton's and Yellowstone quite a bit.
In the past I've experienced a lot of weak signal if any at all in my FW. I have a Net Gear WI-FI extender here at home that I am not using anymore. My question is, will it work in my FW and on the parks WI-FI? If not or there is a better way, what would you guys recommend?
I've also never tried using my cellphone as a hot spot in the past. What is everyone's experience with a cell phone hot spot? Or, is there a better system to that, and the cost of it?
Not streaming movies, but wife and I do use our WI-FI a lot here at home, what is the average that two people would use? Thanks for every ones input.
  • I use a Verizon 'Jetpack' on a monthly basis. It's a lil' pricey, but secure with WPA2 and VERY fast and reliable. Since I work when we have an extended camping calendar it's necessary.
  • scbwr wrote:
    I've just recently purchased and set up the equipment described on this blog:
    Signal booster and more!
    I'm on the road on a 6 week trip, and I've used it a couple of times and it's working well. I like adding a layer of security for when I have to do a few banking chores.
    If you watch the video, you'll see that it requires a certain level of computer skill, but if you can handle it, it's a great option for under $100. But, as clearly pointed out, all you are doing is amplifying the campground signal. Most of the time, there isn't anyway that you are going to stream video using the internet signal provided by campgrounds.
    This is just one option. I don't have any experience with tethering via a smart phone. And, I've never wanted to get into the expense of any dish based system.
    I ordered one of these and already had Ethernet patch cables, so cost was $68.50.
    It took me about an hour to set it up with a Windows 8.1 laptop while watching the video on my desk computer. Of course I am a retired data network engineer and did a lot of poking around. Looking at things like the list of users in the airGateway etc.
    I see us using it on the boat to get marina WiFi and in the Arizona RV park to get to the towers. I use to use an usb high powered external WiFi unit, but could not get it to run on the windows 8/8.1 machines.
    I would note that the power on the down stream side to your computer, phone, tablet or other device is turned down by default, so I could not see the airGateway from 50 or 60 feet away inside our home. We have two WiFi router in the house and I could see the one close to this unit at the other end of the house with my smart phone. I bought the unit into the living room and it connected on the top side to that distance router with a much stronger DB reading than my smart phone. So if you want more range to wonder around with a mobile device you will want to bump that downstream setting up in the airGateway(the 192.168.1.1 device). I may test that out a bit tomorrow, however in the boat or trailer that is not an issue. However to let friends in near by boats relay through it for marina WiFi it may need to be turned up.
    We do have tethering on our Verizon Moto X's, however that can eat up data pretty fast.
    I also have a Verizon Jetpak setup on Telus in Canada that I use on the boat or when at our friend ski condo in Canada.
    A person can not have enough weapons in their data/internet arsenal. Chris
    Chris
  • Naio's avatar
    Naio
    Explorer II
    I love using my phone as a hotspot. It has good security built in, I think -- a password to connect, and (optionally) a white list of computers that are allowed to connect. It is also very fast.
    I can see on the phone screen a list of currently connected computers. I check that before I do my banking, make sure it is only me.
  • Thanks again guys, all this different info really helps. Now to figure it out.
