krazymattExplorerJun 20, 2015Will a dirty magnet cause intermittent brakes?So as I continue on my quest to solve my intermittent brakes issue I took off one drum and there is a film of grease on the drum and magnet probably from those useless easy lube fittings. There was a...Show More
Bamaman11ExplorerJun 24, 2015You can replace the grease seal, clean up the brakes and even sand the brake pad somewhat. It may get you back on the road.
Related Contentintermittent brakesIntermittent brakes!!!!Intermittent brake failureAre these brake magnets warn?1984 carriage brake magnets
