- JKJavelinExplorer IIII must be extremely naive....
- way2rollNavigator II
dryfly wrote:
Very common with newer 5th wheels. Most economical and effective solution is to let the air out of the two tires on the other side of the trailer. Lots of YouTube videos on this subject.
Best answer! - way2rollNavigator IINew member, first post, a word salad of grammatical errors and the question is - if 2 flat tires will cause a FW to lean??? If this isn't a troll post I don't know what is.
- LynnmorExplorerDon't they put air in at the factory? :h
- Weak springs will cause a lean.... Weak springs happen.... BUT... 2 flat tires on the same side would cause a BIG LEAN ! ! !
Figure that the side with 2 flats will be close to 5-6" lower than the other side... Have you NEVER had a flat on any vehicle before to notice? - BurbManExplorer II
cavie wrote:
Is this a trick question?
I don't know, is it? Or does it just look like a trick question to trick you? - Tyler0215ExplorerHow could two flat tires on the same side cause a tilt?
LOAD THE PARTS CANNON! New springs, shackles, shocks. But don't air up those tires. - buckyExplorer IILooking at the join date this is just another in a long string of such things.
The best PDI in the world is worthless in the face of the RVing buying onslaught. - cavieExplorerIs this a trick question?
- dryflyExplorerVery common with newer 5th wheels. Most economical and effective solution is to let the air out of the two tires on the other side of the trailer. Lots of YouTube videos on this subject.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
