troutbum53's avatar
troutbum53
Will a Gold Wing Trike fit in a 10' garage
We are looking to buy a new Toy hauler and we want to haul our Gold wing trike. We would like to stay as short as possible on the length of our TH. Our trike is about 9'4" and I was hoping a 10' garage was big enough, has anyone hauled a GW trike? Any input would be appreciated....thanks!
  • Go to this URL to see the pic.
    http://i184.photobucket.com/albums/x293/N90atcguy/2014%20Durchmen%20VORTAGE%203200/015LoadedUp_zpsca7fb22d.jpg
  • Is it because i,m new that i cant see pictures. It says image not shown due to preference settings. I cannot find anywhere to change it.
  • This is a Wing in a 10' garage to give you an idea of what you're trike will be like. I believe this TH is a Voltage 3200.
  • Y-Guy wrote:
    If you measured it and you're really at 9'4" you should be ok there. The other issue would be the height and if it can ride up the ramp without bottoming out.
    As you have heard, it will fit easy enough, but as stated the ramp angle can be the biggest issue if the trailer floor is not dovetailed. I have run into high center issues even with the dovetail in my trailer.
  • AZ, That is good news for us, we have found the one we like, but the 10' garage was a concern. Thanks for the info...:)
  • Yes, your trike will fit with inches to spare. My Wing measures 5" shorter than your trike when installed on the Condor chock and there is about a foot of room between the bike and the ramp door. Also, due to the Condor front chock I'm using, I'm not as far forward as you can get your trike.
  • That is a concern of ours also, I plan on trying to load it at the dealers before making a final deal, I would sure hate to buy it and find out it won't fit or that it did bottom out.
  • If you measured it and you're really at 9'4" you should be ok there. The other issue would be the height and if it can ride up the ramp without bottoming out.
