coolmom42
Nov 17, 2014Explorer II
Maybe close most of the vents from the furnace, to everything but the tank area. You may have to put something under them, depending on how they are made. Then set the furnace thermostat to some point warmer than you will keep your living area. That should make the furnace kick on some. Heat the living area with the fireplace & space heaters.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
