C-Bears
Nov 17, 2014Explorer
drillagent wrote:
The furnace vents into the tank areas keeping the plumbing from freezing. But the temp sensor for the furnace is located in the bedroom. The furnace isn't very effective at heating anyway, so I need to supplement with the fireplace and space heaters.
How do I run a space heater in the bedroom without shutting down the furnace risking frozen plumbing? Is there a way to switch zones on the Dometic thermostat?
If yours is like mine, there is a sensor on the ceiling in the bedroom, but the Dometic digital thermostat also is a sensor for your other zone. In my case zone 1 is my living room/kitchen, and zone 2 is the bedroom/bathroom area.
You are 100% correct about needing to run the furnace occasionally to keep some heat going into the underbelly of a Montana. They have a 2" heat duct pipe that goes into the underbelly from the furnace.
Currently the temp here is 19 degrees with winds building to 30mph. We have ceramic heaters going in the basement, bedroom, and living room. We also have the fireplace on. About every hour I will turn the furnace up to 73 and let it run for 10 minutes or so, then turn it back down to 68. This way we are keeping the inside around 70 during the day, putting some heat in the underbelly, but not using much propane.
At night we set the furnace on 60 but keep the ceramic heater on in the basement and bedroom. This keeps the bedroom/bathroom floors warm along with the bedroom itself. The furnace will run about every 20 minutes at night so I know there is plenty of heat getting to the underbelly.
Hope this helps.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
