donn0128 wrote:
3500, you will never regret havine enough capacity.
Yes, until you pull into a parking garage, while your out exploring on your travels! Yes I am all for safety but if you plan on using this anywhere except in a dry campground you have other things to think about. Is this vehicle going to be dedicated to just pulling the fiver? If it is, then by all means get the biggest baddest TV you can afford! If you plan on using it for something else, then ....! Also, keep in mind many 3/4 ton vehicles are the exact same vehicle as their 1 ton SRW counterparts! Difference, in some states the 1 ton gets extra taxes and/or license requirements! Do the research, check your anticipated pin weights, check the ratings of the tires, and wheels. If RAM, is a "Heavy Duty" with the same engine, transmission and rear end as the 2500? Make an intelligent informed decision!
