Poppy_s_5th_Whe
May 06, 2017Explorer
Durb wrote:
I see you positioned your Andersen kingpin adapter to the rear of the the trailer. Can I ask why you did that as opposed to positioning it forward and giving you more clearance?
I have plenty of clearance and what I was looking for was more room within the rails. Positioning the adapter this way moved the pin box in so I have no concerns about the down plates or the pin box hitting the bed rails.
In my last truck, also a 6'6" bed, I had the adapter in the normal position and the down plates hit my DS bed rail and dented it during an awkward turn on uneven ground. This is much better. As you can see I also have plenty of clearance over the tool box and I have plenty of turning radius.
So, yes, wit the adapter in the "standard" orientation I may have more clearance up front but I never make turns sharp enough to be problematic but I did have issues within the bed, so this orientation resolves that. I have now towed with this setup for about 6,500 miles and I love it.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
