QFP
Nov 29, 2015Explorer
Winch in toy hauler Garage
Has anyone mounted a winch in their garage? if so, would you share some ideas on how you connected it? For instance, is it permanent or quick release?
taken wrote:Yes, you are lucky whether you realize it or not. You're lucky that the manufacturer of your rig took the time to install the d-rings properly. It's common knowledge that quality control is sometimes very lacking in the TT industry. I can't tell you how many d-rings I've seen pull loose that were simply installed with self-tapping screws.
Not "lucky" at all. The D rings in my RV are rated to 5k and screwed/bolted into a metal brace under the flooring. Most decent haulers are built the same.
