ith0's avatar
ith0
Windmill usage
I am looking at a small windmill to use on my property while living in the 5th wheel. Eventually we will be building on the property but until then I am looking at this as an alternative. I have a Heartland Gateway 3800RLB. 2 AC units and 3 tv's as well as 3 computers and the inside and outside fridge and a washer/dryer combo. The windmill produces a daily output of 5 kWh at mean wind speeds of 5.5 m/s.
We have a propane heater and stove as well as water heater.
Outside of needing to run the propane for heater and hot water, might this be sufficient in Colorado where the temps get up to the 90's and as low as -20?. Would it be better to have that and solar combined.
  • I built last year used little solar panel while I was at work. Just to keep batteries up. Then when I got back to site I fired up my generator. I have a honda 7000 and a cheap 9000 I left for the workers. Once I had hydro ran to the site I had a 30amp plug put in where my trailer was all summer. But in your case I would try to get power ran to the lot
