wskiExplorerDec 10, 2013Window slipping1. The window in my door will slide down, leaving a small gap at the top. Is there an adjustment I can make to fix this?
enblethenNomadDec 10, 2013You can get replace cat's wiskers to go in the track. Most glass shops should have it. You may want to take existing out to get correct size of replacement.Here is example of track for Hehr. You may find make of window in lower corner.Window seal
Related ContentDrivetrain slipping?Cleaning Onan generator slip ringstongue jack slippedLeveling blocks slip5th Wheel took out rear window
