Steve76eb
Jun 30, 2014Explorer
broccoli2 wrote:
Oh, Boy, Oh and the wood decretive trim on top of both the slides in the main living/kitchen feel down (at different times)
Just found the big center chunk of trim laying on top of the island counter when we got home this weekend. The little trim nails were barely long enough to go through the both pieces of trim to the wood framing underneath. I reattached it like the bedroom one with screws, so if the LED strip behind it goes out and I choose to replace it, I will have access to do it. The bedroom one has screws holding it up, so you can have access to the slide motor should you ever have to manually retract that slide.
On this weeks trip we also had mice running around inside at night, so I took the time to seal up all the gaps between the frame and the coroplast. Lots of gaps around the spring hangers and where the coroplast ends at the fuel tanks. Once they get in the underbelly they just made their way to the basement where there is a huge hole in the floor for a couple water lines and the push/pull cables for the gray and black tanks. Once inside there it was easy to fit through the wooden grate/vent next to the fireplace that hides some access to the heater.
On the plus side I did find there is a wireless Samsung subwoofer hidden in the basement behind the fireplace. Don't know if it works or not, but it is there.
About Fifth Wheel Group
