the_bear_II
Jul 30, 2015Explorer
If it's surface rust the dealer should take care of it. A little sanding, a good primer with rust inhibitor and a couple coats of paint and you'll be good for about 10 years. Surface rust is mostly a cosmetic problem.
If the rust has eaten holes in the frame, that's another story. A replacement would be warranted.
You need to send a registered letter with signature receipt. Send a letter to each of the executives and one to the general manager of La Mesa. Include photos. The letters will give you a paper trail in case you decide to go to court. Be sure to write down everything you are told with dates and times for each contact.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
