DutchmenSport wrote:
Yes, you can successfully camp in winter-snowy weather in an RV, but in order to ensure your water lines do not freeze, the water system needs to be winterized. This is by far the safest way to ensure old man winter doesn't damage your system.
Then, you use water, very much like you would if you were tent camping. No running water inside the camper. Absolutely no water down the drains. Absolutely do not use the toilet. Why? Because water freezes, and then pipes break and valves burst.
If winter camper, we bring water with us, separate, in containers. (I now have a 35 gallon tank we use). Water is never flushed down the toilet. We use a port-a-potty and dump in in campground outhouses. We do not use chemicals in the port-a-potty, but we do dump it and rinse it every day.
We heat water on the stove, take cat-baths, and catch any water in the sink in a tub in the sink and then toss it out the door. (like brushing teeth, sponge bath, etc.)
Being in the Army a few years we had to learn to live with water only from a canteen and enough water to fill our helmets for bathing, brushing teeth, and anything else for personal hygiene. The advantage of an RV? You can heat the water on the stove first!
Cooking? Gas stove? Dishes? Wash in a tub and dump it outside or in a pit toilet, just like you would if you tent camped.
This is really the only sure-fire way to make sure no water freezes in your camper. 4 season campers means very little. If you are camping off the power grid, you need heated tanks, that takes power, LOTS of battery power. 4 season means the air ducts for the furnace run under the floor and along the water pipes, and that's all. There are reports of pipes freezing inside the coach, under cabinets, and right above the floor. Your best approach is to use the camper with absolutely no water in the tanks or the water system, just as if you were in a tent. This is how we do it. It works well for us, but ours is usually just a week-end jaunt. State Parks in Indiana have power at the campsites all year round. But after October 31, the water is shut off. So, no bath houses, no water at the dump stations, and those state parks with water at the sites, are turned off also. Bring it in, take it out! For us, this works.
X2
Buy a case of the cheap RV antifreeze at Wallys and use that to flush the turlet when needed. You can at least dump the pink stink out. It sucks taking a shower with it though.
