babunExplorerSep 13, 2015Winter shirting on a fiberglass keystone cougarI'm going to be installing insulation boards around my non moving cougar 5th wheeler soon. Would be real easy if I could run a bead of some kind of glue/sealer along the lower outside of the rv and t...Show More
CalicajunExplorerSep 14, 2015Adding skirting around the 5th wheel will stop air flow. Will you cause a problem with mold and rot building up due to no air flow?
Related ContentKeystone Bullet Premiert shirt for everyoneLaminated Fiberglass WallsRear Fiberglass Cap DamageFiberglass wax
