B_O__Plenty
Sep 14, 2015Explorer II
babun wrote:A300 watt ceramic won't put out enough heat to keep your fingers warm if you were right next to it, let alone warm anything under the trailer. A 1500 watt heater only puts out 5,280 BTUs. Do the math....A 300 watt heater will produce 1,050 BTUs. about the same as a couple candles.....
I was just under the beast and it looks like I could box off along the frame rails nice and easy with the insulating boards. This will not help 100% with keeping heat in the rv but it will protect all the tanks, lines, mechanics, which is my main concern.
My plan was to heat the underside with 2 small 300watt ceramic heaters to prevent freeze ups.
What ever I do I will post pics and results after the first deep freeze. {I don't believe I just said "deep freeze", in Tenn.!!! {I'm from upstate NY originally}
B.O.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
