babun's avatar
babun
Winter shirting on a fiberglass keystone cougar
I'm going to be installing insulation boards around my non moving cougar 5th wheeler soon.
Would be real easy if I could run a bead of some kind of glue/sealer along the lower outside of the rv and then stick the 1" thick 4foot wide boards to that then to the ground.
Any body know of a sealer/glue that will clean up easy next spring when the shirting comes off?
  • whiteeye42 wrote:
    RTV silicone would work but i would think insulation boards would be to light weight to with stand any type of wind
    As a retired construction site foreman, I still have "cheap' access to industrial 4'x 12' long, one inch thick or 2 inch thick insulation.
    It is pretty strong, especially since it will be only about 2 feet high from ground to bottom of RV.
    I have a way of securing to the ground, my concern was/is the glue/sealers affect on the gel coat of the rv.
    Don't want to remove them next spring and pull chucks out of the Cougar!!
  • RTV silicone would work but i would think insulation boards would be to light weight to with stand any type of wind
  • Not sure of the composition of the insulation you will be using but you might also consider some of the various tapes available. On house trailers I see a 2x2 framing is often used.
