12t1 wrote:
nevadanick wrote:
The carbides will probably tear up the rhino, i have used these http://www.trailerpartsdepot.com/itemdesc.asp?ic=CR0121&eq=&Tp=
Thanks...I had those on a 2 position open trailer. This is 80% car trailer and then we will try to get 3-4 sleds in for some winter trips. I'm thinking get them up on dollys and winch them in to place because driving that many in might be difficult...that way we can bring them in backwards to try to fit 4.
thanks
yes I think a pro is necessary. I suspect it would be better to install the windows after and that way they can blast through there fast. Are you saying the foam will be 3" thick from the skin up to the interior edge of the beam? so oyu can see the beams or would they go over the beams too? How thick? ANy pictures of trailers with this anywhere? Is it easy to cut like "Great Stuff"?
