Kenc_AL
Jan 27, 2014Explorer
pa traveler wrote:
Good ideas,cant go south yet maybe in 4 or 5 yrs. A garage or pole barn might be an option,what about co2 build up in a garage? If the camper is in there. Just crack a window in garage? Not sure how much need to watch with propane furnace? Any ideas on how to vent furnace out of garage?
I cannot imagine you building a polebarn tight enough that some air would enter to clear out the CO2. Keeping the exhaust in would help keep the barn temp up.
But if you want to vent it, use 4" or 6" PVC or wood stove piping to pick up the exhaust and run it up and out. I would incorporate a couple 90 degree curves to help capture some exhaust radiant heat inside pole barn.
Consider installing a Co2 monitor in the pole barn.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
