gbopp wrote:
Just blow out your water lines and pour some pink stuff in the traps.
It's quick and simple. Then you don't have to be concerned with dropping temps and can do it after every trip during colder weather.
X2
Your climate is about the same as we have in the PNW. Do you plan on using the 5er through the winter. We use to go out all winter long I would just keep an eye on the temps if it was going to drop below about 28 overnight, I would blow the lines and put pink AF in the traps.
If we went out and the weather was still mild would wait for the next cold spell before blowing the lines.
As we used the 5er through out the winter, would only blow and Pink if temp was going below 28 overnight.
We had unit stored at a storage yard, and I had/have onboard air so easy to blow the lines. Never an Issue.
Enjoy your new climate, get out and enjoy winter camping!! We would keep the 5er stocked with cloths and non perishable foods so only needed to grab perishable food from home refer.
