RoyB
Nov 05, 2014Explorer III
My off-road POPUP is a small footprint water system and it just didn't make sense to go through a hugh winterizing method. The shower portion is part of my cassette potty install.
This is basically my small trailer water system layout..
My effort is to just drain all the fresh water at the low drain ports which will also drain down my hot water heater tank if I open the blow out pressure value and open the hot water water sink faucet. The water left in the hot water tank is just a tad left over which has plenty of room to expand and has never presented any freeze up problem associated with the water heater tank.
I can remove my cassette potty black water tank with ease and can dump it properly. I also have a small 6-gallon fresh water tank associated with the cassette potty setup which has a low point drain port.
Then I hook-up my 12VDC tankless compressor using an air adapter to the city water fill port and flush all of the water from the one or two line which drains down the sink drain. after all the water is out I then fill the sink drain p-trap with pink stuff...
We sometimes camp in our mtns during the winter months and can do this blow-out procedure in only a few minutes and then can re-fill the fresh water tank the next day when it warms up...
Having a larger trailer I would probably change my winterizing procedure somewhat but for the small POPUP footprint this works out great for me and can be done anytime the weather conditions gets down to freezing in just a few minutes of effort...
Roy Ken
Roy Ken
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
