happycamper1942's avatar
Dec 17, 2018
Winterizing - remove batteries or not?
Do you remove your batteries when winterizing? I usually do but am thinking of leaving them in this year. I live on Vancouver Island where we get quite mild winters, very few days below freezing and the coldest I've known it is about -10 C. what about wrapping them with some insulation?
  • My batts are outside animals.
    Anyhow,I don't see how wrapping them in insulation will help any.
  • I like to run my generators (Hondas) once a month during the winter. I let them run for an hour and that gives the batteries enough of a recharge to keep them at 100% charge during the off-season.
  • I keep our in and keep power to the camper/battery during the winter. Have been doing this for years.
  • I leave mine in the TT with a good 3 stage converter taking care of them.
  • If your battery is fully charged, no issue regarding freezing until -92F per Trojan
    https://www.trojanbattery.com/pdf/WP_DeepCycleBatteryStorage_0512.pdf
  • The colder it is the less need for fully charged batteries to be moved to storage.
  • I take mine out and put them on the Battery Tender in my heated garage.
  • No reason to remove them, unless you are concerned about theft. If they are charged, it makes no difference if they sit in your camper or in the garage in your house.
  • As long as batteries are fully charged, and then disconnected from loads they will be fine over winter. I mainly remove them due to theft issues when left alone at storage. Your in a pretty mild area so I would ensure cells are topped off, charge them up and remove leads.
    Daryll
