Old-Biscuit
Oct 29, 2016Explorer III
Locate backside of water heater tank....directly opposite outside compartment.
S/B at least ONE valve...cold inlet
That cold inlet may also be the bypass valve.
Handle parallel with cold water line...cold inlet
Handle perpendicular with cold line (90*turn...parallel with cold to hot line...bypass setting)
No valves would be very unusual....find backside of WH Tank and LOOK.
Trace cold/hot lines----shutoff valves would be fairly close by
Air pressure...blowing out lines OK provided you get ALL the lines
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
