TakingThe5th
Aug 15, 2013Explorer
I understand B4s concern with the city water line. When I checked all my lines for pink after winterizing, I caught a glimpse of clear pipe at a tee. That pipe still held fresh water and proved to be the city water hookup line.
I blow the system out with compressed air b4 I pump in the pink stuff so you can imagine my surprise at finding clear water in that line. That is why I play with the check valve as I explained previously.
Concerning the hot water tank bypass valve, it should work OK. Also remove the anode rod from the tank.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
