Kordog
Oct 19, 2014Explorer
I blow compressed air through the lines and open the faucets and valves one by one until only air comes out, I don't like using the pink stuff in my water lines, takes too long in the spring to flush it out, empty my water heater, and pour the pink stuff down my drains, and I only use the anti-freeze without the alcohol, so the rubber seals don't dry up. I did forget my washer lines though until I read through here!! I will be doing that ASAP, so thank you for that!! Disconnect the battery, and pull it out, put it inside on a charger if possible. I also blow compressed air through my black tank flushes.
About Fifth Wheel Group
