gsutton wrote:
thanks for the info kinda what i expected or maybe a faulty pump.where is the pump located and how did you get to it?
Mine is in the basement area just behind the hot water tank. You will likely have to remove a panel to get access to it. I removed part of the wall in my basement then cut it so I don't have to remove the whole section each time. I cut it where there was an upright support. Now I can remove a small section to get to my pump.
My model is different than yours so it won't likely be the same. You could turn the pump on and listen for it. It may help you locate it.
Good luck.
