gsutton wrote:
not pumping antifreeze or anything else anywhere. have turned the bypass both ways and still nothing.i have gathered by having this "freeze guard" all that is necessary is to turn the one valve to winterize. obviously that is not the case. no luck at all on finding info on this "freeze guard".
keystone advertises this as "no fuss" but no info that i can find.will call keystone tomorrow and see what they can tell me.
thanks for the replies
There should be a hot water bypass at the tank. If your winterize valve is like mine it was likely installed wrong or faulty. I think my dealer had a few 2014's with this problem. If you can get to the pump it's very easy to install your own winterize bypass kit. Then you can at least see if your pump is working ok.
Does it draw water from the fresh water tank? You may have to fill it at least a 1/3 full to get it to draw.
