bid_time
Dec 21, 2016Nomad III
- Drain the low point drains (you should be able to find these by crawling under the trailer)
- Drain the water heater
- If you have an ice maker I can't help you here
- Pump pink antifreeze through the lines using the onboard pump (this should be the way you did it with the last trailer). If you don't have the by-pass line on the pump for pumping in antifreeze, buy a by-pass kit and install it on the suction side of the pump.
- Pour Antifreeze in the drains (traps)
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
