ScottG
Mar 13, 2018Nomad
Captain_Happy wrote:
When I did have an Ice Maker in refrigerator all I ever did was drain the water out of the incoming water line going to the Ice Maker. The Ice Maker itself, nothing. It's already inside the freeze so it's already frozen.
Most of the ice makers water supply lines are not inside the freezer.
If no one comes up with a better method, I would at least disconnect the water line that runs from the fridges electric valve on the back to the ice maker and let it drain out.
If it has a water dispenser there will be a small tank hidden inside the fridge someplace that will also need to be drained or protected from freezing as well.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 17, 2026
