- KID2TEXASExplorerThe voyager works great it locks in real nice, I have a 36 ft 5er and no issues at all. If it does go a little low then just adjust the antenna on the monitor if needed but like above usually always good signal strength.
- larry_barnhartExplorerWhy not hard wire the camera to the monitor? You want the best signal you can get or you will be un happy. We had a back up camera installed on our truck and did not buy a cheap model. I cannot tell you how happy it was for me to have it for backing out of parking sites last winter in Az. Old neck is the reason. We don't back up much with the fifth or we would have done what you are thinking. good luck on your purchase. Always best when buying new to set it up and enjoy .
chevman - C_B_Explorer II
Field Trip wrote:
Does your Voyager send a good signal for the distance?
Friend of mine and I both have 40 Cedar Creek 5th wheels with Voyager Wireless Cameras. We found it necessary to extend the antenna cable from the rear cap to the front cap to keep an uninterrupted signal.
We both used:
1)80" antenna extension part #WVOSANTEXT
2)35' extension cable part #WVOSANT-EXT35
Ordered from: link
rvcams.com
C.B. - MrDExplorerI have a voyager also and it works great with my 35' trailer. The signal is usually 2 out of 3 bars
Mike - Field_TripExplorerDoes your Voyager send a good signal for the distance?
- KID2TEXASExplorerI have the Voyager on mine and it works great.
- Dick_BExplorerMethinks we just discussed this. Try searching this Forum for `back-up camera'.
About Fifth Wheel Group
