720Deere wrote:
So if I'm understanding you correctly, you are suggesting that I strap my smartphone to the back of my toy hauler?
depends on your usage requirements.. I don't use or need a camera
for normal road use, only backing up in odd situations, then i have
the wife point the camera behind the rv so i can see where i'm going..
I did use it alone once, I strapped it to the rear ladder and it was sufficient to enable me to see where I was heading..
If you need a road camera then there are better options I'm sure..
OTOH.. you could strap an "old" smartphone to the rear..
using the WiFi does not require any active carrier plan..
I'm just thinking outside the box.. you don't need any other video monitor, assuming you have another phone you can use..
