justme
Nov 11, 2017Explorer
justme wrote:johndeerefarmer wrote:neal10a wrote:
I have the Voyager and it works well on my 40ft 5th wheel. It does wag out once in a while traveling at highway speeds. I does better after I put the antenna straight up. I also have a Ford truck, but I doubt the Ford TPMS is the problem because its operating frequency is much lower than the Voyager frequency and is not at any harmonic. I believe the problem is the ground plane for the Voyager which varies when traveling. However the signal loss is not bad enough for me to improve the ground plane which would be a little tricky. The Voyager is suppose to have it own ground plane, but it is evidently too small. Increasing the voltage to the transmitter would be another option by running a separate wire for power. Presently I have it connected to the trailer marker lights which are not LED and the power at the Transmitter is less than 11vdc. Maybe changing them to LED would be helpful as well. But the problem is not bad enough for me to hassle with.
What are the freqs for the Ford TPMS system and the Voyager? Since the camera cuts out at higher speeds and the Ford TPMS kicks in at higher speeds its likely there is interference between the two. Get a spectrum analyzer if you are really curious.
The low voltage isn't the problem as mine does the same thing and my voltage is no where near that low. Also I have the repeater installed and it still does the same thing so it's not a signal strength issue either. You can add a counterpoise to the Voyager antennas if you want but it would be a waste if time.
Ford on the '17 Super Duties went with a WIRED system to avoid these issues. The TPMS sensors on the truck "talk" to the receiver mounted on your trailer and then the signal is fed via wire to the truck.The camera for the trailer is hard wired as well.
The FCC allows for items like TPMS to operate at 433mhz and items like Video monitors to operate at 2.4 ghz. I believe that Ford like all other mfgs operate in 434mhz or 315-330 MHz(Europe operates at 434Mhz and the rest of the world at 315Mhz) band. Both of these devices use digital type modulation so they can be encrypted or provide digital identification techniques. Otherwise they would be interference between automobiles, trucks and other rear view video monitors and devices as they pass each other on the highway. The reason video monitors operate at a much higher carrier frequency is because of modulation requirements of the RF. Tire monitor information does not require as high frequency to modulate the carrier as video. Also digital reception by nature of encryption is generally immune to interference as compared to analog reception.
Also the FCC limits to power that can be transmitted. Power is a function of voltage times current. For the camera manufacture to guarantee that they meet the FCC power requirements they design their units at 14-15 volts. Therefore at 12 volts they are below their rated power spec. So the lower the voltage to less power. Therefore it makes sense to get as power as possible to the transmitter.
Could you provide verifiable information as to your claim that Ford TPMS interfere with RF backup cameras? BTY if Ford did interfere with those devices they could be in violation of FCC rules.
About Fifth Wheel Group
