deleted-2
May 04, 2013Explorer II
OnTaMove wrote:
I guess I am a bit clueless, but...why do you need someone to help you avoid backing into things with a 5th wheel but you do not need the same with a MH+toad?
As mentioned with a fifth wheel backing a longer (or any length actually) alone involves a lot of exiting the driver seat to check the blind side.
If it's a straight back in and the driver can see both sides of the coach then it's easier.
When backing in at angles accomplished with what I call a "crab" turn.
The opposite side (or outside of the crab) of the trailer becomes not visible to the driver in the outside mirrors.
It can be done it just takes a lot of effort.
About Fifth Wheel Group
