tonsyukonxl's avatar
tonsyukonxl
WW fs3000 axles
Hi. I have a 2007 we fs3000. My hub and wheel came off coming back from glamis. I tried researching what axles I have to fix problem. Do I have Dexter 5200 axles? If not what do I have? What would be replacement part number for hub drum bearing race kit and brakes? Thanks!
  • Thanks everyone. Finally found the tag... 6000 lbs Al Ko axles. 6 lug. Now just need to get parts numbers or kit to fix.
  • As stated, there is a tag on the axle.
    I have 6000lbs axles as well. 2006 LE3905
  • As a few others suggested, get under there and look for a metal band/tag wrapped around the axle.
    I looked at mine while doing other work just a few weeks ago, mine are AL-KO 6,000lb axles. That's on a WW 2006 FSC3200 triple axle. And most likely Dexter makes a kit that works.
    Good Luck
  • If you have dexter axles they usually have dexter stamped on the brake drum. 5200# axles have 6-lug wheels
  • Although they went out of business in 2009 seems they have started back up..........LINK
    710 W. Simplot Blvd.
    Caldwell, ID 83605
    Give them a call with your VIN and they should have info
  • Crawl under the trailer and look for a metal tag attached to the axle somewhere. That will tell you everything you need to know.
