dwrat wrote:
WH1234
30 items?
sounds like you may be a little picky. I fell for any company thats sells to you.
I agree with Alx, you need to get a little handy.
I am picky and I should be. This unit retails for $49,000. It should not have the problems that it has had. There is not quality control that I can see. The frame around the oven was bent and cracked. The bench fell apart and had to be replaced. I have had three water leaks, two electrical problems, floor started bubling up on the inside and had to be replaced,the plastic undercarriage came off driving down the road,the shower walls began bulging away from the wall and had to be re-glued,...etc. I can fix quite a bit, but items like this I shouldn't have to. I even bought an extended warranty but I cannot use it as long as I am still under the origianl warranty and my unit is still new. I would take it back if I could, but it appears as if I am stuck with this so I need it fixed.
