JIMNLIN wrote:
There are many options in this size tire, a couple with claimed "LT" designation as well. LT just doesn't mean what people think it means, when its still a tire designed for trailers.
A LT tire is still a LT tire regardless of its intended usage. If your referring to the G614 RST Goodyear says it is designed as a LT tire that is intended for the Regional Service Trailer industry (RST).
Wrong...and right. Wrong stating an LT is an LT. As LT's made for trailers are generally not found on any truck and not made at all the same at true Light Truck tires...not even close. So don't be fooled.
The Kumho's and G614 in particular could be considered so by some description, but they are not produced in the correct sizes. They are trailer tire sizes only. Also, the Kumho's do not have LT designation on the side either. The G614's do, but you'll never find it on any truck!
