ependydad
Dec 02, 2014Explorer
lpxguy wrote:
Nice work! Only difference in the way I did mine, and you may want to rethink yours....I did not tap threads in to the pin box. I went the bolt & nut/washer route. There's a whole lot of leverage on a few bolt threads with 4 bikes bouncing....I was not comfortable with that thought...wouldn't take much to pull those threads out.
How I did it....using grade 8 nuts & bolts I used extended handle long nose needle nose pliers & held the bolt from the inside of the pin box while my neighbor started the nut on the outside(after applying Loctite). When all 4 were in place I was able to hold the bolt with a long box wrench while he torqued the nut on the outside. I then marked the nut/bolt with a sharpie so I can keep an eye on any movement.
I've read a few descriptions of this bolt-thru plan. I'll watch it and see how it goes. Thanks for the info on how you did it in case it comes to that.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
