rhagfo wrote:
BillB3857 wrote:
Test #1... Interlace your fingers, then point the index fingers away from you. Hold a pencil between the two index fingers. Have someone pull the pencil in the direction you are pointing.
Test #2... Interlace you fingers, then extend one index finger. Place a pencil against you knuckles and wrap the extended finger around the pencil Have someone pull the pencil away.
You decide.
Test #3 ... Interlace your fingers, then point the index fingers away from you. Hold a pencil between the two index fingers. Have someone pull the pencil in the direction AWAY FROM you are pointing. This is how Reese jaws work!
Reese doesn't require "Cocking" just return the locking handle to the latched position once you unhitch. Jaws are closed, then just back in to the hitch, jaws open and snap shut, you can do a Pull test right then not going anywhere.
Way too many people over think the hitching process.
Thanks for your insight on the Reese Dual Jaw set up Russ. You helped me understand this hitch better about a year ago. Now it's my preferred design. (After the handle modification)
Thanks!
Jeremiah
