countryriders3
May 16, 2019Explorer
50 amp
Don't know if this is possible. Is there a converter that I can use to go from normal 110 or 220 volt to 50 amp?
WILDEBILL308 wrote:
So many people giving the wrong answer to the OPs question. Amps and volts are 2 different things. You can't convert amps to volts. Think of it this way volts are the size of the line. Amps is the preshure pushing through the line.
Bill
Well no it isn't amps and volts are 2 different things. You might do a google search on the subject.
Bill
one_strange_texan wrote:
Your original question is unclear, as others have said. If indeed you are trying to get 50 amp service off of shore power poles that have only a conventional 15-20 amp household plug and a single 30 amp plug you might consider one of these:
Amazon link
I have gotten an earlier version of this to work, but it seems to work best using two power poles if you have a vacant site near you, using a 30 amp extension cord to the other shore power pole. For those of you who might think I was "stealing" power, I was on a daily rate which included all electrical consumption. I have also tried this on a single shore power pole using a 30 amp female to 15 amp male adapter. It didn't work as well and tended to pop breakers.
It is certainly an adaptation and it's better to just have a 50 amp source.
Amazon link
