cuzbcuz's avatar
cuzbcuz
9 months and no major issues
We have been living in our 5er for about 9 months now. No major issues, but we are wondering about the black tank? There are several people that are work camping and we have never seen them dump or flush their black tanks? The other issue or concern we are having is our main AC is tripping almost every day, it is a dometic duo therm, is any one else having issues with this unit? Temps behave been pushing 100 degrees every day. Any advise or imput would be appreciated.
  • BarbaraOK wrote:
    And in 7 years we have never felt the need to rinse the tanks. Just wait until there are full (burping at us) we dump and put water in the tank to start over again. If stationary for more than a few days I'll leave the gray open using the washer and just make sure I do a load after I dump the black tank to flush the hose.
    Barb
    Good luck with that method. Not sure why you would not take 5 minutes to make sure it is actually clean. You may be slowly making the dreaded Pyramid!
  • Cummins12V98 wrote:
    Barb
    Pyramids grow wihen people who don't use enough water to ensure that all solid matter is completely dissolve, plus we move around so we get a lot of agitation. And since we have 7 years fulltiming, I'm pretty sure we have a good handle on it.
    Barb
  • cuzbcuz wrote:
    Campground host checked the volatage and it is between 108 & 112, which should be OK. We talked to a RV repair tech and he thinks that the washer/dryer might be causing the triped breaker. This is due to the load on the system during the hottest part of the day. He also suggested that we get the units serviced. I think that cleaning the condenser coils and general maintence would take care of the service issue.
    108-112 volts sounds pretty marginal. Was the voltage checked during a high demand period? You may also want to check the female receptacle at the post. I'ts possible one of the pins is burned and may also be burning one of the pins in your plug. That's not too uncommon, in my experience.
    If I noticed voltage that low I'd run other appliances (fridge & water heater)on LP rather than electric, as was suggested by another respondent. I'd also run the A/C unit temporarily on "fan only" (compressor off) when using the microwave.
  • BarbaraOK wrote:
    Cummins12V98 wrote:
    Barb
    Barb
    Glad it is working for you.
    BarbaraOK wrote:
    Cummins12V98 wrote:
    Barb
    Barb
    It is no secret how to avoid pyramids, plenty of water , it works for many. I have had rv's that have had no way to flush other then using one of those wands or keep adding water ,and flushing. Been doing this over 10 years ,and have had no problem . Water, water,water keeps things from building up. I don't care if dump evert three to four days because of using lots of water. If I want to take the five minutes to flush some more I do, if I don't it is no big deal to me. Ya it works for me also.
