matemike's avatar
matemike
Another Question
As some of you know from my prior posts, my wife and I are planning on full time RVing in less than a year. We don't want to spend a lot of time at rv parks so we need an rv with ample holding tanks. Question: on average what size holding tanks are needed to stay out of rv parks as much as possible? Thank you.
  • Hi,
    I full time with 66 gallons of fresh, and 40 each for black and grey tanks. If I shower once in three days I run out of water in two weeks.
    Another consideration is power. I hope you plan on a good solar system, or you may find yourself running the generator LOTS.
    Plan for at least 400 amp-hours of battery bank.
    My propane tank is just 20 gallons. That can be an issue in cold weather. I can run out in 3 days.
    In the extremes of cold and heat it is usually cheaper to go to an RV park.
  • Other things will make a difference also. If you go to some cheaper places or little county parks or bare minimum spots they will often times have anything from a plastic pota jon to a very nice rest room. You dont have to use the rest rooms all the time but it saves your black tank capacity. Some might be only $10.00 and limit you to 14 days or so and have a dump station, rest rooms, showers, and a water faucet. With those conditions it's easy to stay put for two weeks then dump and move on. Worst case you may have to walk a few buckets of gray water over to the dump.
    I have been in areas that let you dig 6 inches deep and bury black and gray but x number of feet from lakes and streams.
    Wife doesn't use the rest rooms that much because she has a hard time squatting while both feet are up on the toilet seat.
  • Just keep in mind that you are most likely going to need to dump about once a week or even more often depending on how much water you use...showers, washing dishes, etc.
    As posted by 2oldman above, most tanks are in the 40 gal. range.
    The black tank will last much longer than the gray tank(s).
    I think it will be hard (not impossible) to Full Time long term by just boondocking.
    Anyway, good luck with your upcoming adventure.
