Jaygonz's avatar
Jaygonz
Best Full Time Living Travel Trailer?
Hello,
I am in search of the best quality and most reliable travel trailer for full time living. The travel trailer I am looking for must be around 25' not much less or more, I also need to be able to get an artic package on it for all 4 seasons, and of course, I need it to be able to withstand full time year round living!
Thanks in advance!
  • "Arctic" packages are a euphemism. If you want a TT that is a bit better suited to the cold than some of the others, look at Arctic Fox. All of the mainstream manufacturers use the same appliances and fittings, and many of the same components such as slides, axles, suspension, etc. You pay your money and roll the dice.
    Rob
  • You are asking a lot, they are not designed to be lived in full time. Many do it but they make a lot of sacrifices. In cold climates you will go through a LOT of propane, water pipes tend to freeze etc etc. Will the trailer be parked so you can skirt it? One Ohio winter will adjust your priorities.:B
  • Even with the “best” trailer and four season package, winter camping requires lots of effort, propane and electricity. Airstream would be the choice of many for “best.” Oliver and Bigfoot might have an edge in cold weather but the Olivers are narrow. Which trailers has your research shown meet your requirements?
