- Skid_Row_JoeExplorerI went with the one Walmart Supercenters sell. Works great too!
- GoPackGoExplorerI cannot recommend a Valterra. I bought a nice one with a gage and it decided to start leaking at a casting joint after about 4 months of fulltime use. Looking at other reviews of that model on Amazon, mine was not the first one to have this problem. I now have a Watts on order from the RV water filter store.
- NolanExplorerWe have the SharkBite® Soloset® EB-25 Pressure Regulator. It has a convenient orange pressure adjustment twist-cap, and numerical indicator on what you want to set the water pressure at. Easy to do. Set it and forget it. Have had it since the summer of 2006.
- SCRExplorerThis is what I've been using Hi Flow Water Regulator - Lead Free on my full time rig @ $12.30 on line purchase
- Bird_FreakExplorer III installed this one from Home-Depot inside. Model # 3/4 lfx65bu. $43.59, set at 50 psi. Works great.
- simsfmlyExplorerI got my 263A from the RV Water Filter Store dot com.. Only $129.93 with shipping to Texas.
According to him "If you choose one of the 263A models I offer, where you put it will make a big determination of the best choice. If going out in the weather, the s/s exterior parts kit gets rid of the standard zinc coated parts that get rusty. The oil filled s/s gauge gets rid of the dry gauge that also deteriorates out in the weather within a year, or so. If going inside, the standard model is fine."
Hope that helps. - paulcardozaExplorerExpensive, but will last forever......
Stainless Steel Watts Adjustable 263A Regulator, 2 1/2" diameter w/oil filled stainless gauge. External and internal parts are all stainless except for fittings. ~~$180 - Teacher_s_PetExplorer
RVnRobin wrote:
Golden_HVAC wrote:
:h What Home Depot did you go to? I priced it out and it came to about $200 with all the necessary parts. :(
Hi,
What would be wrong with a 20 GPM model from Home Depot with 3/4" in and out? You can buy brass connections for garden hose in and out, then put it all together for about $50. Then have plenty of flow, while having an adjustable pressure regulator.
Fred.
Just walked away to look for something that doesn't break the bank.
The Watts pressure regulators for "boilers" are 3 to 10 times than "wholehouse" versions for water only.
We bought ours from The RV Water Filter Store at a rally 9 years ago...use these Watts model numbers for a google search. - RVnRobinExplorer
Hi,
Fred.
Just walked away to look for something that doesn't break the bank. - tsetsafExplorer III
Golden_HVAC wrote:
Hi,
Fred.
We use a watts household type from home depot. While there pick up the whole house water filter and plumb it all inline after your flow valve.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
