23mikey
May 12, 2022Explorer
Cptnvideo, your setup is similar to ours. Factory installed residential Samsung 18cuft had it's own 1000w inverter, for traveling. I have added 1200w solar and 3kw inverter. With adequate sun our batteries (4x100ah Li) are back to 100% by mid-day. The one thing I found to be most helpful on the Samsung is to turn ON the E-Saver feature. I believe it turns off the door seal heater to keep moisture and condensation to a minimum. Really only needed in high humidity areas and a definite energy hog.
Safe Travels,
Mike
Safe Travels,
Mike
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
