The_Works
Jun 08, 2013Explorer
Dish Antenna
I beleive the satellite dish antenna receives, probably dc voltage, from the receiver to operate. There is a F type jack on the side of my camper labeled satellite. There is a cable tv jack next to th...
The Works wrote:If it's just a straight-thru connector, not a splitter, then most likely. You are right, there is a voltage which the receiver supplies to the lnb, and that gets messed up with a splitter.
can I use the satellite jack on the side of the camper for my dish antenna.
