jerryleejr's avatar
jerryleejr
DMV issues
Ok, short version sold the house and went full time, did all the research set up a mail service etc, The DMV is not wanting to take it for my tag renewal. They need a physical residence within the county. Any ideas?
JJ
  • Technically, you are homeless.
    We ran into this years ago and they suggested putting down a family members address. Probably not 100% legitimate but no one really cares (do be up front with your insurance company though).
    Mail forwarding services fall into the same category, you can't actually reside there but in some states, they don't really care to pursue it.
  • Here's what I have done to get around the PMB issues,
    we use the Good Sam/PassPort America system in Crestview, so our address is:
    5753 Hwy 85N
    Suite xxxx
    Crestview, FL 32536
    By using Suite with your box number makes it good to go for most cases.
  • My friend had the same problem in TN. He finally just gave up and did it through FL.
  • A fulltimer that doesn't own property (land), can essentially choose any state as a residence. This is our 2nd time fulltiming and we remained AZ residents as we own a house in AZ that we rent out.
    But the first time fulltiming, we chose South Dakota as our state of residence and went with a mail forwarding service there. Never had an issue with the SD DMV.
  • A mail service simply gives you a box, a Personal Mail Box, PMB. You couldn't reside in that PMB, so that address isn't a "real" residential address.
    Some such as Escapees and St. Brendan's Isle can provide you a real address that you could live at, a domicile address. You would also become a legal resident of Texas or Florida for better or worse.
    escapees.com
    sbimailservice.com
  • The Escapees website has a section with info on domicile issues. I’d check here https://escapees.com/?s=Domicile
  • If in FL you can set up your legal domicile in Bushnell using the Escapees services.
  • Call the local DMV closest to where you lived in a stick and brick and explain the situation to a supervisor. She/he should be able to give you advice if you want to maintain same state for other reasons (insurance, license etc)
  • I used Good Sam Mail Service in Crestview FL.
    No problems since 2015
