ScottG
Jan 29, 2014Nomad
You can make two heaters work but either you have to make sure every other big load item is off or use the type that you can set for 750 watts (or 1 @750 & 1 @1500 maybe.) and position them so they cover the entire RV.
Keep in mind that all electric heaters are nearly 100% efficient so it doesn't matter what you spend on one - they all put out the same amount of heat.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
