Johno02
Jan 29, 2014Explorer
One solution used by many is to run an extension cord in and plug the heaters into the 20a plug at the post. This takes some of the load off the RV internal circuits. CAUTION: If you do this, make sure that you hava a heavy-duty extension, under 25' if possible. Do not overload an extension cord!!!
Also, using the 20A outlet in addition does not increase the amperage that the campground provides to the site, just splits part off the RV wiring.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
