rockhillmanor
Jan 29, 2014Explorer II
mikeleblanc413 wrote:
RE: 2000 Winnebago Minnie Winnie, 30 ft., no slide, 30 AMP
I am currently using a Lasko ceramic tower heater and want to know if there is a better option and can I make two heaters work? THANKS!
I have spent 100's of dollars and tried them ALL!
After 6 years on the road trying all the different heaters, you have the one that I have finally settled on. IMHO, it's the best.
I just saved you a $100! :B
And....NO. You can't put two heaters on without blowing the breakers all the time. You might get by but don't make coffee, toast, or have the DW use the hair dryer at the same time. :W
BTW: The 'only' thing I don't like about the Lasko is they eliminated the tip over switch. So be careful. Their so-called UL approved safety is if it tips over it will shut off AFTER it reaches a certain temperature which is 'already on fire'. :R
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
